TEMAHOME 9300.167454 NILO WALL MODULE PURE WHITE FRAME - PURE WHITE DOOR
Modern flavor with exquisite minimalist design. Nilo can be found on the wall or on the floor as this line has three distinct pieces: a wall module a TV table and a shelving unit. All the pieces present a modern flavor with minimalist design. Its sliding doors allow the user to choose which part of Nilo is viewable. The contrasting finishes are suitable for a sophisticated interior in any corner of the world.
Features- Matte white finish frame and door
- Left compartment 13.3" high x 28" wide x 9.6" deep right compartment divided in two sections 6.3" high x 28" wide x 9" deep by a fixed shelf
- Panels made of honeycomb inlay framed with chipboard and encased in an MDF shell that is veneered or painted which reduces weight but increases durability and strength. Clean with damp cloth and avoid solvents.
- Requires attaching support bracket to wall proper attention needs to be paid to the amount of weight that the wall can support
- Designed and made in Portugal
Specifications- Finish: Pure White Frame - Pure White Door
- Country of Orgin: Portugal
- Materials: Mat Lacquer / MDF / Honeycomb
- Dimensions: 16" H x 59" W x 12" D
- Weight: 50 lbs
Price: 569.40
