MAHAR MANUFACTURING N60DCASENV DOUBLE SIDED BOOK CASE IN GRAY NEBULA AND NAVY EDGE
Convenient contemporary and space-saving storage units are a perfect solution for classrooms daycare libraries and the home. They can be used to create natural room dividers in shared spaces. The double-sided units give dual versatility and roomy storage to hold supplies or effectively display books and classroom aids.
Features- Heavy duty construction-built to last
- Unit do not have casters
- It will not fade or discolor and is easy wipe clean
- Its safe non-toxic and stain resistant
- Matching colored cubbie trays (sold separately).
- Oversize hard duty casters for easy mobility.
- Color is not as shown in the image
Specifications- Double slided book case with caster
- Fixed Shelves - 4
- Finish - Gray Nebula
- Edge Color - Navy
- Dimension - 36 W x 25.25 D x 60 H in.
Price: 536.79
